430W rear wheel hub
Tractor Rat
12-25-1999 18:33:31
I have a JD 430W with a bad rear wheel hub-the internal spines are twisted out. This is the small cast iron hub with a tapered internal bore with four internal grooves to match the buttress style spines on the axle shaft. I believe that this hub design may be unique to the 430 series. I am also looking for an intake/exhaust manifold for this same tractor. Any information, parts sources, etc. would be greatly appreciated. Please feel free to E-mail me at [email protected]. Thanks, the Tractor Rat
Phil Sutton
12-27-1999 05:53:22
 Re: 430W rear wheel hub in reply to Tractor Rat, 12-25-1999 18:33:31
I have a 430W standard I am using for parts for myself. I hate to get rid of any part I may need.
I could probably sell one hub. The problem is that I had one heck of a time getting a hub off of the 430 I am rebuilding (had a bad seal).
I had to rent a very large puller and heat the nut on the axle, and then jump up and down on an extension bar on a 3/4" drive socket. When the puller popped off the hub it shot half way across the barn. Maybe one of the other hubs would be a little easier. I won't be around until after the first of the year.
