2510 haying question
Randy G.
12-28-2006 14:01:47
I have a 67 2510 gas syncro WF. Can it power a round baler and if so, which one? I"m not sure at this point if it has a 4 or 8 cylinder hydraulic pump. I think it has the smaller one. I"m a hobby farmer and would like to leave my 2 cylinders for smaller tasks rated for their horse power yet I"d like to use the 2510 for some what modern tasks on my pasture. Please let me know the 2510"s capabilities. Thanks!! Randy G.
Glen in TX
12-28-2006 22:39:46
 Re: 2510 haying question in reply to Randy G., 12-28-2006 14:01:47
Like said below it will work better with smaller 4.5 to 5 ft. balers for yourself and not lots of custom work. We had a 2510 diesel with syncro and it worked great on a round baler for just ourselves on a 676 NH ? It was one with chains making the 4 1/2 ft. bales. Later we had a 688 NH with belts and it worked great on the 2510 too but we had put the larger pump on it by then and you could easily set it for small or large bales. Depends on what you are baling and it would do straw in larger bales just fine but set it back to 4.5 or 5 for haygrazer or alfalfa. The 4320 did great with larger round baler of course.
JDknut
12-28-2006 16:30:58
Congrats on the 2510, that's one of the finest tractors of that size ever made. That's a good utility rig, will handle any haying chore in the square bale line, but might be a taste light for a round baler unless it is a smaller round baler (4 to 4 -1/2 ft. diameter, 1400 lbs, these usually ask for around 55 PTO HP). Put a loader or bale spear on it and you'll do OK, also can pull a wagon or run a mower or small moco (8ft-9ft cut). If your tractor is tuned up well and in good shape you might be able to push it a little for hobby purposes but most farmers here (Northern NY) use at least 75 HP for production round baling and moco-ing. Hope this helps some.
