Early styled B
teddy52food
12-28-2006 10:25:12
I am working on the clutch. The driver was loose. If I tighten the nut, it gets tight on the crank again. But it also locks the pully & shaft together. The splines look ok on the shaft. Is the spline wore out in the driver? Any way to fix? If I turn (in the lathe) the back side of the driver, can I still have enough to adjust & keep it from slipping?
Mike M
12-28-2006 11:10:58
 Re: Early styled B in reply to teddy52food, 12-28-2006 10:25:12
On some tractors I have turned some off the backside of the driver and made them work. Everyone is going to be different so it may or may not work on yours. You may also find another used or new driver and try it or I have even made a one piece steel shim from a can and fit it to the splines then put the driver on. This has worked on light duty, but if worked very much it might not hold up unless you also add some JB Weld. Some have carefully welded up the splines one at a time and worked them down to fit the driver or even pulled the crank and sent it off to a machine shop to get a real good job done. So it all depends on how much you want to spend and how hard it will be worked.
Ken Hansen
12-28-2006 11:05:40
I have a 45 "B" and this is what I did and it works for me. I took the driver off of the crank and cleaned the splines on both with some brake clean. Be careful ot to get any on any seal or anything similar. Then I smeared some JB Weld on the crank spline as well as the driver spline. Then I assembled the clutch. After assembling the clutch I loosened the nut on the end of the crank approximately 1 turn, then pulled the driver out to the nut. This assures clearance for the clutch disc. Then let the JB Weld harden and its good to go. If it is cold then you may want to put a light bulb near the clutch to keep the JB Weld warm until it hardens. I let it harden for 24 hours. It sure beats buying a new driver or having the spline on the crank rebuilt.
teddy52food
12-28-2006 14:07:02
 Re: Early styled B in reply to Ken Hansen, 12-28-2006 11:05:40
This sounds good. But did you ever try to remove it later?
Mike M
12-28-2006 16:22:07
 Re: Early styled B in reply to teddy52food, 12-28-2006 14:07:02
The one I made a shim for and then JB welded it was a working tractor the shim alone didn't hold up ,but it did after the JB weld. When I put it together I didn't clean one part good so I hoped it would not stick as good. I never did have to work on it again. I guess heat would release it.
