Full steel or cuttoffs
cory scharf
12-28-2006 10:24:23
What will cost more? A full set of steel or a nice set of cuttoffs with good/almost new tires. This is in referance to an early 30s D.
What are the going prices for both?
Ken L.
12-28-2006 14:33:12
 Re: Full steel or cuttoffs in reply to cory scharf, 12-28-2006 10:24:23
I would say that the steel would cost a little more but, think about this. I have an early 27 D on steel. Bought it that way 42 years ago. Four years ago I tore it apart for the second time to make it look good again. I thought about changing it to cut-offs but I didn't and never will but, steel can be a pain in the blowhole. I have new original style lugs on it so, to show it, I had to make roadbands. Loading it can be scary. I've had it slide down the ramps and even slide sideways. If you want to "use" it, the bands have to be removed. I think steel wheels make any tractor look way better than anything on rubber but, if your going to go that way, even though you may think that is the best way to go, excercise your leg because at times, you will want to kick yourself in that thing right in front of your rear pants pockets.
Jason Mills
12-29-2006 05:38:57
 Re: Full steel or cuttoffs in reply to Ken L., 12-28-2006 14:33:12
Ken, you should get an old set of tractor tires and cut the tread off to put on the road bands. Will keep it from being a slider. Works good on my neighbors tractor that he takes to shows and parades. Have a good one, Jason.
