Hydraulic lines
tstex2
12-28-2006 07:42:19
Hey Guys,
Not a specific JD question, but could not think of a better place for advice.
I have a 1997 M5400S Kubota with a frt-end-loader that i bought new. My hydraulic lines have been springing leaks one-by-one [have replaced 4-5 lines so far].
I keep the tractor completely covered while not in use. I only have about 500 hrs on it [i know, that is sad, but i use it when i can].
Should these lines be leaking/springing leaks like this? They are 3000PSI black rubber/single braided lines...is there something i need to check or do? Also, some of these lines are so close to the hydraulic controls that they could not have been scraped or damaged while using the frt-end-loader or i would have know it. Thank you inadvance for your advice.
Regards,
tstex
tstex2
12-28-2006 12:44:41
 Re: Hydraulic lines in reply to tstex2, 12-28-2006 07:42:19
G/M,
The hoses lasted about 10 yrs, but i agree with you both. The hoses i am replacing with is 2-ply instead of 1 and 4000psi instead of 3K psi. I think your advice on getting rid of all of them at one time is a good idea.
Thanks and Happy New Year,
tstex
Glen in TX
12-28-2006 08:25:02
You'll end up replacing them all eventually. Like Mike said just go with the heavier ply hoses. Might want to get some made at a industrial bearing place if others only have cheap hose. On a UFT feed grinder we had to replace all the cheap metal hydraulic lines with hose within a year or so. Makes you wonder what the designer engineers were thinking?
Mike M
12-28-2006 08:04:02
I had a woods backhoe that had some kinda cheapo hoses on it from the factory. Sounds like that's what your fighting. Use good 2wire hose for the replacements and then they should last a long time. You may just want to replace them ahead of time for saftey.
