throttle rod for D
bigtim72
12-27-2006 18:34:53
can anyone tell me how long the throttle rod from the governer to the carb. is on a 1934 John Deere D is? mine is missing and I would like to make a new one from steel rod thanks for any help
Marty Z
12-29-2006 07:58:32
 Re: throttle rod for D in reply to bigtim72, 12-27-2006 18:34:53
1935 D is 19 inches from center of hole to center of hole . Rod is turned down at carb and turned up at gov . 3 holes are drilled for spring cotter pin and first hole starts 8 1/2 inches from carb end. The rod does have 2 bends in it to line up with the carb so you might have to add a half inch to total length before you bend to fit. If you need a pic I can send you one.
Good luck Marty Z
Marty Z
12-28-2006 22:31:14
Glen,
Give me till tomorrow and I will post the length of the rod on my 35 D.
It is too late for me to go out to the barn and measure now.
MJZ
Glen in TX
12-27-2006 21:12:07
Have several laying around but would have to measure one. I'd sell one of the rods with spring assembly too if you needed it. The rod D1926R is same from 1931 D #109944 on up to 1953 D so not hard to find.
