MT starting crank
49MT
12-27-2006 03:49:49
I'm wondering where I can get a starting crank for my '49 MT.
The original 6V starter works fine; I really want a crank only for conversational purposes.
Any leads will be appreciated.
...sjs...
John Moore
12-28-2006 07:32:01
 Re: MT starting crank in reply to 49MT, 12-27-2006 03:49:49
I bought one for an M from the guy on Ebay (fastnerspecialist). Works great and has a spin handle just like original. My neighbor asked, "Are you having starting problems?" When I told him no then he wanted to know why I had the crank. He can't understand that I just wanted it and it's a part of JD history. Seriously, the part I got from him works really good and there is no problem when the engine starts. Look him up on Ebay and send him a message. Best wishes, John
tstex
12-27-2006 05:55:52
49MT
Conversational purposes is a good thing. I have heard, and read, that if you ever do get the urge to hand-crank her, you really need to insure your elbow/wrist are correctly positioned in case of a "back-lash". One of those can seriously injure your arm.
Good luck and i hope everyone and their family has a safe, healthy and prosperous New Year.
Regards,
tstex
49mt
12-27-2006 07:00:44
 Re: MT starting crank in reply to tstex, 12-27-2006 05:55:52
Thanks for the tip, tstex. Back in the day I had an old farm wagon that started life as a Model B pickup that we cut the bed off of and laid in a gob of 4 by 4"s for transporting hay bales for feeding cattle during the winter.
This monstrosity had no electric starter, and on those cold central Oregon winter mornings, hand-cranking the beast was a real treat. ;-)
One thing everyone learned *VERY* quickly was the proper way to hold and "pull" the crank; never grip and push. One backfire would ruin an entire day.
Fast forward 20 years, and I had a restored Triumph TR-2 with a hand crank. Just for kicks, I had to start it by hand a time or two.
Crank-starting any engine by hand is a lot like riding a bicycle; once one learns how, one never forgets. But, of course, pain is a powerful teacher!
CPeter
12-27-2006 04:40:10
There is one on E**Y right now.
CPeter
49mt
12-27-2006 07:04:13
 Re: MT starting crank in reply to CPeter, 12-27-2006 04:40:10
Are you referring to item #130062675008? That says it's for a 40, but the picture indicates that this seller has all manner of cranks.
Anyone done business with this fellow, and would like to share their experiences, good or bad?
green48
12-27-2006 18:08:49
 Re: MT starting crank in reply to 49mt, 12-27-2006 07:04:13
I bought one of the starting cranks for my 1948 M. At the time, the listing was for the "M" and it fits my M fine though it looks like the 40 crank pictured in the ad, not the M crank (I'm referring to the picture of the four JD cranks mounted on a board). The crank that I received matches the M crank shown in my parts manual, which looks like the MT crank, but the MT crank has a different number and the MT has an additional starting crank shaft (AM 3149T) not on the M. Maybe that just makes the MT crank shorter and then the M crank would still work (or could be cut shorter to work?
In any case, when I first got the crank I used it to turn the crankshaft several times. It worked, though I had to push in against the tractor with a fair amount of force while also pushing the crank around. I have not tried to actually start the engine -- if I had it sounds like I should pull then crank instead of pushing it. Any other tips? Since the crank doesn't lock onto the pulley, does it back itself out some and then disengage and stop turning so that it can be pulled out without loosing a wrist? There is nothing specific in my operator's manual and I mainly got it for the novelty. Would have been nice to have, though, when I first got the tractor and the battery was shot.
