630 JD radiator
TLP
12-26-2006 17:34:46
Need to replace core in radiator. How is the best a way to get the bolts out of the cast iron pieces? Where is the best place to get the radiator core and gaskets?
P Browning
12-27-2006 06:54:02
 Re: 630 JD radiator in reply to TLP, 12-26-2006 17:34:46
Here is an excerpt from the JD-H Restortion Guide which has worked well for many. (PatB)
Radiator disassembly, cleaning and repair --- For most John Deere two-cylinder tractors including the "H", the radiator amounts to four pieces of cast iron and a copper core bolted together. The top and bottom tanks, held in strict relation to each other by the two sides, envelop the core. Many small cap screws and/or bolts hold together the sandwich of iron pieces and the top and bottom plates of the core. This is their interface. For a Spruce up, one may be spared the task of disassembly, provided the radiator isn't leaking and the tractor isn't overheating. For Restoration, or for a tractor that hasn't been running for a very long time however, full disassembly is the way to go. This means removing many small, perhaps rusted-in 3/8-16 and 5/16-18 inch studs and/or cap screws from the tank castings. Prepare the radiator well in advance. Apply several liberal doses of penetrating compound (PB Blaster� or Kroil �) to nuts and bolts and to studs and cap screws. Allow a day or two for soaking before attempting to remove them. Techniques vary as to how to back these stubborn fasteners out of cast iron. Application of heat is too risky -- it may damage the core. A firm grip between fastener and wrench is foremost. Then apply short, swift suitable force. Think "impact", sort of a lunge -- but not with overwhelming force! Some sort of shock works best. Slow, steady force has a tendency to twist off the fasteners. Try working it back and forth. Replace all the 5/16-18 fasteners with new stock and chase all tapped holes in castings. (An impact wrench would do just fine, but getting one in position is difficult).
Separate the pieces, applying utmost care to protect the core from any stress or shock whatsoever! Most likely, one or more of the fasteners will twist off. One must then use wisdom, and conventional methods of removal. Complete the removals and make other repairs as necessary such as welding a crack. Clean and prepare the various castings (sandblast and prime if called for), straps and fasteners for painting. Sandblasting can be an effective means for dealing with rust inside the tanks once separated from the core. Following prime painting and before finish painting, use appropriate sized bottom taps to chase all threaded holes in castings. Insert dummy bolts into threaded holes prior to finish paint. Unserviceable threaded tapped holes in the tank castings should be over-bored and fitted with suitable Helicoils� or Keenserts.� JB Weld � can come in handy to back-fill huge voids in the tank casting's gasket regions. Clean all debris from the core with shop air. Straighten the copper fins of the core (BONDO� applicators come in handy for this). Once all cleaning and preparation is finished, the core is generally left in its oxidized copper color, and the iron pieces all painted John Deere Classic Green. Allow sufficient time for the paint to cure before final assembly.
