2355 brakes
Mike Jarvis
12-26-2006 15:42:17
Looking at JD parts.com,my 2355 has planetary gears in the final drive.On level ground with the trans in neutral,should I be able to move the tractor a little by pushing the rear tires.It will not move.A friend says this is because of the planetary gears.I hope he is right because I thought I had a brake problem.Tks for any replies.
low budget
12-27-2006 15:31:05
 Re: 2355 brakes in reply to Mike Jarvis, 12-26-2006 15:42:17
It should roll just fine. Check your parking brake adjustment. However if it is 4wd it may roll harder due to the fact the 4wd is engaged if the engine isn't running. (Hydraulically disengaged, spring engaged.)
las vegas
12-26-2006 20:25:28
my 2155 does the same thing. i bled the brakes and it was able to roll around easy. perhaps this may help you, but you NEVER know, LOL
