'58 720D possible VR problem ??
Scott Griffith
12-25-2006 15:25:50
Background info:
720D with pony motor has a 12 volt neg. ground system instead of 6 volt pos. ground. 12 volt generator with a 4 terminal regulator. (the load terminal is not in use) The fuel gauge wire is on the [A] terminal. The 12 volt Gen is rebuilt and the VR new from the shop.
For some reason I cannot get a pos charge out of the system with the tractor running. If I turn the lights on with the engine on I get a discharge. The fuel gauge works when the tractor is running. When I ground the field (tractor running) I get a 20 amp charge. Could I still have a bad VR? What are some things I need to check for?
Scott
Scott Griffith
12-26-2006 16:42:52
 Re: '58 720D possible VR problem ?? in reply to Scott Griffith, 12-25-2006 15:25:50
I replaced the VR today and the charging system is working now.
Scott
55 50
12-26-2006 08:57:48
New VRs have been known to be bad out of the box.
jhill52
12-26-2006 06:18:02
Maybe the ammeter is hooked up backward.
mjbrown
12-25-2006 16:54:06
Did you flash the generator to polorize it?
Scott Griffith
12-26-2006 03:12:02
 Re: '58 720D possible VR problem ?? in reply to mjbrown, 12-25-2006 16:54:06
Yes.
