2010 distributor
hawgwild
12-25-2006 05:26:35
I am trying to do a tune up on my JD2010. It is a 1964 row crop utility SR number starts with 55.
I purchased a tune up kit for it from JD dealer. When I went to put in the new points I found that the kit from JD does not match the one in the distributor. It is completely different.
I looked on the distributor for the MFG name. The "tag/plate" is missing.
How do i tell which distributor/model # I have. Not sure if it is Delco, Wico, Prestolite..
Any help?????
jdemaris
12-25-2006 08:25:35
 Re: 2010 distributor in reply to hawgwild, 12-25-2006 05:26:35
Early Delco distributor - i.e. 1112577 has a clip-on cap and four-advance weights inside. Takes breaker set LD AT14465 or HD AT14466. Delco scew-on cap distributor # 1112623 or X-23226 takes breaker set # AR31818. Wico distributor # X30091 with clip-on cap, two centrifugal weights inside - takes condensor # AT15929 and points AR12003. Note that the Wico cap-clips are not held by screws - just by hooks. Prestolite distributor IBT-4101 with clip-on cap, two centrifugal weights - takes breaker assembly with plate for early models - AT14683 or for late models AT21719. Note - the cap-clips on the Prestolite are held on by screws.
hawgwild
12-25-2006 15:53:56
 Re: 2010 distributor in reply to jdemaris, 12-25-2006 08:25:35
The distributor I have has screws holding the clips to the side of the distributor. it must be a prestolite. thanks very much.
Happy times re here again.
Happy holidays.
