4020 again
Tom43
12-24-2006 18:33:56
Dear New Generation Experts,
I have spent most of a lifetime working on tractors and cars. I feel pretty competent on two-cylinder tractors but fairly ignorant of the 4020. One of my life's ambitions is to learn how to troubleshoot the injection pump, hydraulics, and be able to work on the transmission of this tractor. Is there any way to learn this? Do any of you wizards(msb,Jdemaris, gman, bob, glen in texas, or others)ever disassemble this tractor? Would you be willing to tutor a student? I realize this is an unusual request but I would appreciate your comments.
msb
12-25-2006 20:53:51
 Re: 4020 again in reply to Tom43, 12-24-2006 18:33:56
Just ask away Tom.There are several here that pretty well know their stuff and even a few that think they know.LoL.
I have had extensive schooling on the New Generation Of Power.Was lucky enough to have attended one of only two 30 day service schools held at the old Indianapolis branch house in 1964 & 1965.Only 6 young men were in my group so we got close supervision and training .We had cutaways of every component on a 4020 as well as a cutaway of a complete 4020 and were required to trace the oil flow through every cutaway.We disassembled, reassembled and adjusted everything that could be taken apart on those 1010,2010,3020 & 4020 tractors.We had a lot thrown at us including oils, test equipment, shop management and several other subjects including the proper way to install a roll pin.lol.We ran out of time so we didn't get to talk about painting ,but I already had a fair knowlege of painting.It was a wondeful training experience.
Also attended a week long school at that same location on 2 cylinder and Roosa Master injection pumps in about 1964 or 65 when we got out test stand at the dealership where I worked.Then I later went to Waterloo two or three times for further training on various injection pumps.Those were also week long sessions.Plus I attended all the annual service schools during the time of my employment.
But like Bob points out, a lot of it is just common sense that can be done by most good mechanics with a service manual and good comprehension and reading skills. And several of those special tools and equipment can be hand made.
Mike M
12-26-2006 06:50:58
 Re: 4020 again in reply to msb, 12-25-2006 20:53:51
That's some intensive schooling ! I wonder if ANY companies offer anything like that today ? And if they would I doubt the dealer would pay to send you to it. I have been in the parts departments of several different types of shops and NONE of them have sent any of the guys off to schools for many years now. Very Sad indeed ! You can see the end results in comebacks and misdiagnosis.
Hayfarmer
12-25-2006 11:43:25
I worked for the local JD dealer at the time when the 4020, 3020 etc were probably the most used tractors in this area. I did most everything on them from hydraulic pump rebuild to transmission overhaul. They are not nearly as technical as the later models but as mentioned do need some special tools. I would not attempt major repairs on one with out the JD service manuel, not IT. They are available, I also like to hav a parts book handy so you can see how things should be put together. I made split stands out of parts from an old IH cultivator, the front, stationary part, is just an A frame with adjustable screws on the base. The rear part needs a wheel. If you look at a JD manuel or even IT and are handy with torch and welder they are not hard to make.
Glen in TX
12-25-2006 09:59:12
This thing won't let me post today?? YT problems? JD SM***** or TM***** service manuals and FOS manuals as Bob mentions or there is the cheaper aftermarket manuals it won't let me mention here today. grrrr.
Tray C.
12-24-2006 21:04:22
I�m still digging up technical info or as well have started to call it trivial things about the new gen tractors. Aside from that though I have had some experience with early model 4020s the serial numbers under 201000 aka non-consol models. I concur with Bob its not much of a step past working on automobiles with maybe the exception of size and a few things like clutch work or trans work. The main point I�m trying to make is splitting the tractor for trans work or clutch replacement is not fun nor is removing the engine but if your careful and follow the service manual it�s not too horrible. The most horrible part I have found was getting those specialty tools Deere contracted out to OTC tools many of them are no longer available and most small tractor shops wont let go of them for that same reason and when and if you do find them it will seem like they are made in gold after seeing the price. I don�t want to discourage you though lots of times you can rent them and borrow them from other people and when all else fails improvise. Used to I know some JD dealers would rent out tools to people but I don�t know if they still do or if it was just my particular dealer. The tractor stand was one tool I could never locate and I never bothered with the dealership service so I made one from 3-inch channel and the back half a 10 ton jack which worked great and I secured the rear end to the jack for safety via chain and binder. Best way to service the trans though is with the service manual it will save you a lot of headaches and show ways to do things you would have not thought of. I�m far from an expert on 4020s myself and I have worked on lots of heavy equipment mostly construction equipment but I am always willing to learn and I always I mean always work on my equipment myself with the occasional advice or assistance from someone of course but never a service department not even for my car and its under warranty.
Best of luck.
Bob
12-24-2006 19:27:11
I'm just quickly passing through on the way to Church, so I'll make this quick... if you are used to wrenching on cars and smaller tractors, you already know most of what you need to work on a 4020.
Deere publishes extensive service manuals, as well as a series of "Fundamentals Of Service" (FOS) books covering an overview of various components.
Also, there is an injection system service manual.
There is a Deere Techpubs site, or call 1-800-522-7448 for more information and pricing on the Tech Manuals.
And, post back with any questions you have! SOMEONE will help.
