JD 300 Backhoe serial/year
railhead
12-24-2006 18:27:51
I have a JD 300 gasoline backhoe, its a GREAT machine. I cannot find the serial number listed on this site. Where could I find info to get year etc on this machine? Serial is T4W1D049811T, type E7300, ser 002033U. THANKS
jdemaris
12-24-2006 18:53:17
 Re: JD 300 Backhoe serial/year in reply to railhead, 12-24-2006 18:27:51
It's a 1967. What else do you want to know about it?
railhead
12-25-2006 05:22:41
 Re: JD 300 Backhoe serial/year in reply to jdemaris, 12-24-2006 18:53:17
well nothing right now. I was able to service it and all the fluids are new now. It is all tight and in good shape, boom has just a slight amount of slop. I guess that ain't bad for a 40 year old tractor. Pins would fix it I think. It was owned by the city and I know they kept it serviced and stored inside. It spent the last 20 or so years digging graves, nothing heavy duty as they have bigger machines to "abuse". It will be my farm hoe and be worked within its limits, hopefully to last for me. I thought it was 60's because the deere on the emblem has 4 legs. I will keep eye out for a manual. Thanks for info.
jdemaris
12-25-2006 06:08:13
 Re: JD 300 Backhoe serial/year in reply to railhead, 12-25-2006 05:22:41
300 is a real nice machine, and pretty easy to work on. Only possible weak spots are - #1 where the front-end bolts to the engine. If it gets loose - the engine block can crack. #2 - the swing on the hoe is one-cylinder insead of two and uses a link-arrangement that wears kind of fast. Manuals are easy to get - just get one for a 1020 ag. tractor instead of a Industrial 300. All will be the same except for the hydraulic pump - if your's has the HD 2.4 U.S. built pump. Manual for the hoe itself will be separate.
