Help! Power Steering pump leaking?
txasylum
12-24-2006 17:00:26
I have a JD-10 service manual for my 1955 JD70 LPG tractor, but the problem I am having is not clearly defined in the JD-10.
My power steering pump (on shaft of fan) is slowly leaking oil. From what I can tell, there is a small hole on top of the outer cover (the one facing the forward just behind the fan). I don't know what the hole is for, but it looks like the oil is coming out of that hole. In my JD-10, it doesn't break it down enough for me to figure this out.
Any help on this subject is greatly appreciated.
Also, I may have to replace the gasket on top of the cylinder head where the water (coolant) housing is bolted on. It looks like a very small ooze in one spot exists. Any suggestions on where to purchase gaskets other than a JD dealer? The dealer seems to double the price on everything, kinda like a Harley Davidson.... LOL
Merry Christmas!
Bob
bassndeere
12-27-2006 17:53:53
 Re: Help! Power Steering pump leaking? in reply to txasylum, 12-24-2006 17:00:26
Hello Bob,
Be careful with the mounting bolts on the water manifold. They will break /twist off in head very easily.
Have fun with her,
Don
Glen in TX
12-25-2006 22:16:26
Maybe a sand hole in casting or a missing bolt or dowel locator pin ?
430WLPG
12-24-2006 17:51:02
The only place you can buy gaskets besides Deere would a auto parts store that sells gaskets in a ROLL(make your own)which on that upper water pipe would be fine.
