5400 oil pressure
BEWILDERED
12-24-2006 16:47:56
Does the 5400 have a low oil pressure shut off on it? Is it effective?
Thanks
leon
12-25-2006 03:53:57
 Re: 5400 oil pressure in reply to BEWILDERED, 12-24-2006 16:47:56
NO, not unless someone has added an aftermarket low oil pressure shut off, the 5400 from the factory didn't have one. In fact, I don't know of a single Deere tractor that was factory equipped with that feature.
G/MAN
12-25-2006 15:31:26
 Re: 5400 oil pressure in reply to leon, 12-25-2006 03:53:57
Most of the newer electronic tractors have it, but it's not always enabled. Usually it's a matter of accessing a controller address to enable it, depending on the model. Very wise to do so on a tractor that's used for stationary PTO work and is left unattended.
leon
12-25-2006 18:02:20
 Re: 5400 oil pressure in reply to G/MAN, 12-25-2006 15:31:26
You're probably right about the later Deeres that are full of electronics, but the 5400 doesn't.
BEWILDERED
12-25-2006 06:16:21
Thanks for the help. I bought a 5400 with engine trouble that was a bank repo. Was cleaning it up and found a small hole in oil pan just above drive line shield. It had been rubbing. Don't have room in shop for it yet, to tear engine down.
Thanks and have a good Christmas.
buickanddeere
12-26-2006 08:24:00
 Re: 5400 oil pressure in reply to BEWILDERED, 12-25-2006 06:16:21
The 5000 and first half of the 5000 Ten tractors are best owned by somebody other than yourself. Electronics/electrical are not complicated. Only two things to know. Ohm's Law and series/parallel circuits.
BEWILDERED
12-27-2006 15:14:25
 Re: 5400 oil pressure in reply to buickanddeere, 12-26-2006 08:24:00
Thanks for the input. I have already purchased the tractor, but my manuals have not arrived yet, and I was curious to have an answer. The engine will need to be overhauled anyway. By the way, why should it be owned by someone other than myself?
John Hurran
01-01-2007 20:50:15
 Re: 5400 oil pressure in reply to BEWILDERED, 12-27-2006 15:14:25
Because he is a SMART A$$. Look at most of his posts and you will see.
