32 inch tires JD H
jojo1079
12-24-2006 10:47:26
Aside from the JD H were there any other tractors that used 32 inch tires, Deere or other wise?
iowa_tire_guy
12-25-2006 07:26:05
 Re: 32 inch tires JD H in reply to jojo1079, 12-24-2006 10:47:26
My Case VAC has 9.5-32 tires. Most VACs had 28 inch but 32 was an option.
Glen in TX
12-24-2006 22:37:29
JD 5010, 5020 & 6030 used 24.5-32 and 30.5-32 and some older JD pull type combines also used some 32 tires also.
Mike M
12-25-2006 03:37:10
 Re: 32 inch tires JD H in reply to Glen in TX, 12-24-2006 22:37:29
ROFLMAO !!! Sorry Glenn I just had a mental image of an H with those tires on it .
P Browning
12-25-2006 06:38:30
 Re: 32 inch tires JD H in reply to Mike M, 12-25-2006 03:37:10
WOW! Mike -- Now wouldn't that be a parade stopper! And just imagine the comments you would hear if you showed up at a tractor pull with 30-inch wide rears on the JD-H!
Glen -- That was a Christmas Chuckler. Thanks. We needed that.
Merrry Christmas Day to all. (PatB)
Glen in TX
12-25-2006 08:55:45
 Re: 32 inch tires JD H in reply to P Browning, 12-25-2006 06:38:30
He asked so told what I remembered with 32 whether it fit the H or not lol. Yeah I once saw a tractor puller pay $$$ to widen out by cutting and welding on a set of those narrow 32" spoked combine rims when all he had to do was go find a used set of rims off a 5010, 5020,6030. That was before later model combines began using the 30.5-32 tires also. I had D with the road gears with 32" Wards knobbies rear rubber and 20" front truck tires to go faster for roading a thresher.
Paul from MI
12-24-2006 11:20:05
Some Oliver 60 row crop and early Ford 9N had 9-32 tires same as an H. Not sure of others, but it is not a real common size. Original H could be had with 7-32, 8-32 or 9-32 tires as options, but now you can only get 9.5-32 as far as I know. M.E. Miller has them or most any good tire store can order.
Paul
