Rusty Junk TX
12-24-2006 07:48:28
Re: Hey, Rusty Junk TX in reply to G Fever, 12-23-2006 18:43:40
I found that thread about three pages back in the pulling discussion under Unstyled A More Power. We pull this tractor in NATPA type rules Div.II not stroked. If your 3mph class has stroked tractors or allows 18.4-38"s, you might want to stroke it. Also, if you are pulling with JD's and in a class with G's, you aughta be on a G because they are hard to beat with any other JD. For the most part, we stay light enough that G's are not in the class. This engine combination was originaly built in west Texas some 10-15 years ago. It is still running the same parts, just in a different tractor. There may be a better way to do this engine combination today. You might ask around about the Cat or Airplane piston set up using 6.75" styled A crank. If you stroke one, I'm sure you can go all kinds of ways. This tractor runs a 6.75" styled A crank and the current 1/8" over aluminum M&W type pistons you get today. About 335-336 cubic inch. Rods lenghtened about .400 or 7/16". It is an unstyled A block and head. Block decked 1/8". Piston is 1/2" from top of block at edge of cylinder, 3/4" from top of block in middle of piston. Not using top ring groove. You can get these pistons already set up for this from Hinrich's Repair. Merfeld Machine and others can do the rods. The head is as mentioned in the above referenced thread. It has a Johnson manifold on top. Stock 71 carb. Isky grind on the cam. Stock rocker arms. X Magnito. Late Styled A clutch and first reduction. Electric start with a John Deere Nipendenso Japanese starter (one like six-cylinder Deeres use). Starter bracket/crankcase cover, flywheel, and flywheel guard from early electric start A. Sucking air thru an original LOOKING air filter system. Thats about it. Got a Taylor dyno but have never checked it. Been told 50hp + set up this way. It holds its own. Used it a couple years ago for a hay ride at Christmas. It is still friendly enough for that (just kinda slow with that reduction setup). After thinking about it, that tractor is basically all John Deere or replacement parts for. Heck, its even A parts out of the model A parts books except the G valves for intakes, starter, manifold, air filter element, and the weld holding the rods together. Have fun, Happy Holidays. Marcus
