1020 slow to no hydraulic
tdfox
12-23-2006 09:11:47
Hello
I have a JD1020 gas. Tractor is having issues with the hydraulic system. Tractor has a loader on it. At times it will work but most of the time it is slow or not functional it just stops moving. I have changed the filters and fluid X3. Is it possible that I need to rebuild or get a new hyd pump? Is there something else that could be the prob?
Thanks
Travis
1020gas
12-23-2006 11:47:31
 Re: 1020 slow to no hydraulic in reply to tdfox, 12-23-2006 09:11:47
There is also a stroke control adjusting screw and a stroke control filter that you could check out.
tdfox
12-23-2006 11:38:35
The loader has been on the tractor most likly since new, it looks as aged as the rest of the tractor (paint,rust,wear).
It did work fine when I first took it over it was just last summer it started going bad.
I had done a bunch of repairs on the tractor, fixed a few hyd leaks, new carb tires and such.
Tractor runs fine just the hyd prob.
Thanks for the replies.
Travis
jdemaris
12-23-2006 11:28:49
Did it work well once and then get bad? Or, is this the first time you've used it with the loader?
Unless it's been upgraded, the 1020 often has a pump too small for loader work. And, any subsequent wear makes it that much worse. 1020 usually has the German Manheim pump in either four piston or eight piston - 6 1/2 GPM or 13 GPM. The latter 13 GPM pump can run a farm-loader okay, but the four piston pump is too small. I've seen many 1020s and Ind. 300s get upgraded to the full-size 2.4 cubic inch pumps. If your tractor once worked okay - and now does not - you have to make sure the pump is getting oil. If it is - the most common problem is often the stroke-control valve inside the pump and it needs to be replaced. There are also many places the you might be losing high-pressure oil beyond the pump - but usually if that is happening, the tractor will start/crank over very hard.
Tx Jim
12-23-2006 09:19:48
Have you checked or cleaned sump screen? What controls loader(scv's or ind valve)? Very possibly has hi-pressure internal hyd. leak. Have you checked hyd. stand-by pressure? Tx Jim
Handsome Jim
12-23-2006 14:49:45
 Re: 1020 slow to no hydraulic in reply to Tx Jim, 12-23-2006 09:19:48
After changing the filter and fluid, that would be the first place I'd check. We have the same setup, 1020 with a #37 loader. My brother did all that several years ago and it was a 100% improvement.HJ
