Eli - I have had to use avgas in a Deere before when nothing else was around. Don't expect any power increase in a standard compression ratio engine. You may have to adjust the carb just a tad as well. Yes, the avgas is a bit more stable, has a few different additives, and so on, but a bottle of gasoline stabilizer is probably more economical than spending the extra bucks for avgas. Your valves will like the TEL, but if the tractor is not run that much, then it really won't make much difference anyway. Here is a quick and easy snapshot of what avgas is, as found on the web: "Aviation gasoline, or Avgas, is the fuel used in aircraft powered by reciprocating, rather than turbo-jet or turbo-prop engines. Avgas is similar to conventional motor gasoline; however, there are several important differences. Avgas is generally less volatile and has a lower freezing point than conventional gasoline. Common additives to Avgas include alkyl-lead anti-knock additives, metal deactivators, color dyes, oxidation inhibitors, corrosion inhibitors, icing inhibitors, and static dissipaters. Three grades of Avgas are currently available in the U.S. and are characterized by their anti-knock characteristics. American Society for Testing and Materials (ASTM) Grades 100 and 100LL Avgas have octane ratings of 100 and are the most widely available. These grades contain about 1.0 and 0.5 grams per liter of tetra ethyl lead, respectively, considerably more than automotive gasolines currently in use. ASTM Grade 80 Avgas has an octane rating of 80, is declining in use, and contains about 0.14 grams per liter of lead."
