70 engine questions?
super99
12-22-2006 15:58:17
I am tearing down a 70 gas and want to check rod bearings with plastiguage to see where it is wear wise. Does anyone know what to torque rod caps to? I stopped at local JD store to look at book but they couldn"t find one for 70. Looked at a book for a G but couldn"t find any torque values in it. I bot 3 sizes of plastiguage, red, green,and blue. Which one should I use? Plan to make some progress over the weekend, Let you know what I find out. Thanks in advance for any info. Chris
Mike M
12-22-2006 17:20:12
 Re: 70 engine questions? in reply to super99, 12-22-2006 15:58:17
Very hard to get a good reading with plastigauge in a 2 cyl. one problem is the weight of the parts ,but more of a problem is that you about always need to turn the crank some to get at some of the bolts. With plastigauge you must not let it move.
DSK
12-22-2006 16:12:39
Rod bearing clearance is .001-.004. Use the green Plastigage. Rod bolt torque is 85 ft. lbs.
