Gas vs all fuel manifold
Danes Dad
12-22-2006 12:16:02
Does anyone know the actual diff. in length between a gas and all fuel manifold on an unstyled A? If I were to switch to a gasoline one what would I have to do to make up the diff. at the carb and exhaust? Any help would be appreciated. Tom
a1938jd
12-27-2006 07:11:28
 Re: Gas vs all fuel manifold in reply to Danes Dad, 12-22-2006 12:16:02
well somebody produced cold manifolds for the us/a because i have two of them, to the best of my knowledge one was produced by johnson wich has a intake throat completely seperated from the exhaust and the second manifold being the same but utilizes a more abrupt turn down at the base, this manifold was found mounted to a hiesler head and is believed to have been produced by heisler. both heads have rectangle ports square exhaust mounts and correct head bolt pattern
a1938jd
12-27-2006 07:08:38
Danes Dad
12-22-2006 14:48:33
Thanks for the help guys. Yes, was thinking more power in conjunction with boring and a later A crankshaft. Some guys around here are doing that and putting a DLTX 71 on too. Another guy told me to just let the factory DLTX 18 on. I wanna compete at the pulls I don't need to "Clean Up" every weekend! Just wanna have fun with Dane along the way. -Tom
Rusty Junk TX
12-23-2006 05:32:39
 Re: Gas vs all fuel manifold in reply to Danes Dad, 12-22-2006 14:48:33
Tom, In my thread yesterday, I thought you were talking about one of the aftermarket unstyled gas manifolds. Yes, everything will bolt up. On a styled manifold to your unstyled head, the front bolt holes do NOT line up, the exhaust pipe mount is different, and the ports are shaped different. Get you a Johnson, Heisler, or Jerry's unstyled A gas manifold if you want gas. Probably good $200 range for new Johnson or Jerry's manifold.
Marcus
Glen in TX
12-22-2006 13:54:24
No need to modify a styled gas manifold to fit on your unstyled A up to 487999. Aftermarket copies of the old Johnson cold style gas manifolds been available a few years now aftermarket and are a direct bolt on with correct square flange for exhaust pipe. This site sells them as do I and many other aftermarket suppliers. Reproductions of the Johnson cold styled gasoline manifolds are available for A,B & G JDs.
430WLPG
12-22-2006 13:49:25
It may bolt up but THE PORTS ARE DIFFERENT, the US/A has a ROUND intake port, the gas manifold is for a early styled A has a OBLONG intake port so the gasket won't fit I tried this already. As far as I know they never made a gas manifold for a US/A
CLW
12-22-2006 13:36:38
Tom, there is an artical in Two-Cylinder on an upgrade for the late styled B tractor from all fuel to gas. In it they talk about the pistons and such but say the gain in changing to a gas manifold in HP is so small it it not worth it. I know that is not what you ask, but if your reason is for more power I don't think you will see it. Like machinery-man ask, is there such an animal made for the unstyled A?
Rusty Junk TX
12-22-2006 13:09:17
They manifold bolts right up and everything bolts right up to the manifold. Check and adjust throttle rod length when done. Have good head to manifold gasket surfaces or have them surfaced. BE CAREFUL that the front two bolts are not too long and hit the brass pushrod tubes in the head when tightening or you may have a coolant leak into the crankcase oil when done. The back two bolts screw into the water jacket. I put teflon thread sealant on all four bolts to keep coolant from coming up between the bolts and hole in manifold. I use bolts because it makes a gasket change down the road much easier. Been there, done that. The heck with the correct police in this area. Have fun and Happy Holidays.
Marcus
Duane Larson
12-22-2006 13:36:00
 Re: Gas vs all fuel manifold in reply to Rusty Junk TX, 12-22-2006 13:09:17
Marcus,
I agree with your comments about using bolts. The correct ones with the correct thread and length are available from Correct Connection for many models.
machinery-man
12-22-2006 13:01:13
Was there ever a gas only manifold on unstyled a. I thought all were designed for tractor fuel.
