Crankshaft bushing for 51 A
Bazooka Joe
12-22-2006 09:47:19
Hey John Deere guys, I'm new to the board. This looks like a good place to get some good info.
I'm working on a a 51 A which has excessive side to side play in the crankshaft bushings. I measured with a tape measure (yes, that much) at about 1/8".
What parts do I need to correct this problem, and where is a good place to buy the parts?
Any repair suggestions would also be greatly appreciated.
Thanks in advance!
Drew
12-22-2006 10:02:56
 Re: Crankshaft bushing for 51 A in reply to Bazooka Joe, 12-22-2006 09:47:19
The flywheel controls crankshaft endplay. Without the flywheel on, 1/8" of endplay sounds about right.
If there is that much endplay w/ the flywheel on, loosen the flywheel bolts and reset the endplay. I usually try to set endplay at around .010"
Bazooka Joe
12-25-2006 20:00:14
 Re: Crankshaft bushing for 51 A in reply to Drew, 12-22-2006 10:02:56
Drew, Thanks for the reply. The 1/8" sideplay I currently have is with the flywheel installed, but I'm not sure the health of the bushing. Hopefully, the flywheel just needs adjusting.
I drove an A just like this one a whole bunch back on the farm in the 70's, but I'd be wise to get a manual and read up before working on it.
One related question- would this excessive crankshaft side to side play cause a gouchey clutch noise whenever the clutch is disengaged?
