2510 loader
Randy G.
12-21-2006 17:02:33
I have a 67 2510 gas. I believe a 146 loader will fit it. A neighbor has one for sale. Whats a fair price for me to pay and what other loaders will fit it? Also, what should I look for when checking the loader out? Thanks!!!
Randy G.
12-21-2006 18:02:57
 Re: 2510 loader in reply to Randy G., 12-21-2006 17:02:33
How can I tell if it has a 4 or 8 piston hydraulic pump? It has dual remotes in back but none in front.
jdemaris
12-21-2006 19:32:24
 Re: 2510 loader in reply to Randy G., 12-21-2006 18:02:57
Just look at it. An eight piston pump has eight pistons and therefore eight caps on the outside of the pump. The four piston pump uses the same eight-piston housing - but every other spot for a piston was left blank - so there will only be four piston caps on the outside with a long blank spot in-between.
msb
12-21-2006 17:38:07
A 47 or a 48 loader will fit it.
jdemaris
12-21-2006 17:06:59
You might want to make sure your 2510 has enough pump to run the loader. Many 2510s without loaders in mind came new with pumps with only four-pistons instead of eight - i.e. 1.2 cubic inches.
