B2920R rear wheel question comments
Duane Larson
12-20-2006 21:20:45
Ten-Twenty,
I looked through my Barber Greene info on wheels and don't find a lot. I have no information on the rear wheels other than measurements and casting numbers, and have no evidence at this time that they were used on any other model, so at least they aren't very common as I have studied a lot of wheels.
They used a conventional (as opposed to wide-base) rim (like used on tractors before 1939 when Goodyear introduced the wide-base tire/rim). The 12.00-28 conventional tire would be a proper size for the 8.00T-28 rim - at least the tire should be a conventional tire and not labeled as 12-28, which is a wide-base tire size.
Sorry I couldn't be of more help.
Duane Larson
12-21-2006 06:21:38
 Re: B2920R rear wheel question comments in reply to Duane Larson, 12-20-2006 21:20:45
Ten-Twenty,
DKG is correct - I believe Industrial Tires were used on BG wheels, and the sizing on them is "conventional". For example, front tractor tires are "conventional" as they were from the get-go and never went to the wide base design. That is why they are numbered 5.00-15, 6.50-16, etc. The same scheme is used for rear conventional tires - back when tires sizes were 9.00-36, 11.25-24, etc. You have 12.00-28 tires, and I believe the Industrial Tire line also uses conventional tire sizing.
Wide base tires and rims have a different shape, and when wide base tires (like 9-36, 11-38, etc.) are put on conventional rims you get what you see with tires on unstyled A, B, G, etc. - not a good match at the tire-rim interface. In 1957 the way of measuring wide base tires changed - no change in the tire design, just how they were measured. So, a 10" wide base became a 11.2", 11 became 12.4, 12 became 13.6, etc. So, there is a meaningful difference between two digits after the decimal point, and a tire which reads 12.00 is not the same tire as one which reads 12 (wide base) or 12.4 (new wide base measurement system).
A bit complicated but I hope this helps. I would contact an industrial tire dealer and see if he can help, but don't expect him to know anything about conventional and wide base - they have always been conventional to him in his field.
Ten-Twenty
12-21-2006 08:11:07
 Re: B2920R rear wheel question comments in reply to Duane Larson, 12-21-2006 06:21:38
Thanks again Duane.
I will check to see what is available in a 12.00x28 industrial tire.
DGK
12-21-2006 04:59:02
Guess I don"t know whwat you have theses rim on but I have a 50 JD Barber Green tractor. I know the tires are wide industrial type tires on it. If you want I could get the size and make. Hope this helps. Doug in IL
Ten-Twenty
12-21-2006 08:08:14
 Re: B2920R rear wheel question comments in reply to DGK, 12-21-2006 04:59:02
Doug,
I would be interested to know if the tires on your B/G are originals or if you have replaced them and what you were able to find available today.
DGK
12-21-2006 11:32:54
 Re: B2920R rear wheel question comments in reply to Ten-Twenty, 12-21-2006 08:08:14
Hi I am sure these tires came on this BG. They are Firestone tires, it says on sidewall, gruond grip road builder, 12.00 X 28 low pressure, heavy duty. Hope that helps. DOUG
Ten-Twenty
12-21-2006 12:10:26
 Re: B2920R rear wheel question comments in reply to DGK, 12-21-2006 11:32:54
Thanks Doug.
According to my sources here, an industrial tire (R-4) that narrow is not made today.
Ten-Twenty
12-21-2006 04:22:45
Thanks Duane!
So, would one put a current 13.6x28 tire on that 8x28 rim? Or, as narrow a tire as can be found today (maybe 11.2x28)?
