950 john deere
g taylor
12-20-2006 18:24:12
I have a 1983 JD 950 with a 3 cyl. diesel engine, the engine was rebuilt this past summer of 2006 and also needed new fuel pump and also rebuilt fuel injectors. This tractor has been taken care of and also repainted and decaled, my john deere dealer nor myself can figure this out. It does not matter what RPM range it is pulling at it still slobbers and has thick gummy liquid stuff in the exhaust manifold and muffler which is also new as of two weeks ago. If anyone has any knowlege of this problem I sure could use the help. Thanks alot
leon
12-26-2006 04:07:03
 Re: 950 john deere in reply to g taylor, 12-20-2006 18:24:12
When you get it diagnosed, I for one would be interested in knowing what you found. Please let us know with a new thread for we'd most likely miss it with just a reply on this one. Thanks.
Mark - IN.
12-23-2006 21:18:31
Don"t maybe have a leak at your hydraulic pump that mounts to the front of your injector pump located at the lower front of the block on the right hand side as you"re sitting on the tractor? As stated by the others, are many possibilities. If you"re having a problem with a cracked block, head gasket or the sort, I"d figure that you"d be seeing overheating and obvious pressure back into the radiator though. A constant gooey substance in the exhaust? Out of curiosity, what"s your hydraulic fluid levels look like, and does your hydraulic fluid appear to be contaminated? Smell like diesel or anything other than hydraulic oil in there? Sure shouldn"t, but may not be enough pressure at the drive of your injector pump to push diesel into your hydraulics, but enough pressure in your hydraulics to force the other way. I wouldn"t be running or using that tractor much until I figured it out. Oil in the exhaust is going to be obvious and easy to figure out as being oil. Anti-freeze in the exhaust is going to be easy too. I can"t think of another fluid on that tractor...except for hydraulic, which is thicker than anti-freeze, thinner than oil.
Mark - IN.
12-24-2006 09:07:54
 Is a 4th fluid...deisel fuel itself in reply to Mark - IN., 12-23-2006 21:18:31
Do you use a deisel fuel additive like Howes or Power Source? Use them all year around. Maybe what you're seeing is something much simpler and less costly like wax? What's your fuel filter look like? Maybe you have a bad batch of deisel and need to clean the tank out for one. What's that filter look like? Try fuel additive and see if that stops it.
I forgot...KISS (keep it simple). Go after the easy stuff first. Good luck.
Mike M
12-21-2006 06:35:17
Rebuilt has many meanings to different people. Something is still wrong like low compression and /or bad injector Those Yanmars burn clean and when worked even cleaner yet clean enough to start burning white in the pipe.
leon
12-21-2006 06:22:30
Have you worked it hard, got it good and hot and burned out all the slobber stuff and it still does it? Does it quits slobbering when warmed up, then starts again when let set and again started cold?
If so, could there be a cracked head, block or bad head gasket allowing anti-freeze into one or more combustion chambers? Is anti-freeze mysteriously disappearing from the radiator? A pressure test of the cooling system should answer the anti-
freeze question. When running, is there evidence of combustion gasses coming out through the radiator filler neck? That too would of course be another indicator of bad head gasket or head/block crack.
