Air Stack Replacement
Tom.NC
10-29-2003 17:27:05
My 52 JD A has a butchered Air Stack. I have purchased a new one from my local JD dealer. After consulting the archives and looking through my manuals I understand that the old stack must be ground off and the new one welded on with a high Nickel content welding rod or Brazed on. I removed the hood today and for the life of me I don't know where to start. I'm not sure if this stack has been replaced before, but the weld job on the stack now dosn't look like something a factory would do. I can barely make out a couple of inches around where it looks like the stack meets the cast. My question is this: Does the cast I'm welding to protrude up into the stack? Is there a lip of some sort or do you ground it off flat. I want to make certain I know what I'm doing before I take the grinder to it. Thanks in advance for the help.
Tom. NC
Ralph WI
10-29-2003 21:23:05
 Re: Air Stack Replacement in reply to Tom.NC, 10-29-2003 17:27:05
The casting extends up into the the air stack. I'm 3/8". I used a 4 1/2" right angle grinder to cut the weld off the old one. New stack at JD was $60-$65. You will want to mount the air cleaner and steering shaft to get the correct alignment on the new one before welding.
Tom.NC
10-30-2003 05:37:07
 Re: Re: Air Stack Replacement in reply to Ralph WI, 10-29-2003 21:23:05
Thanks for the info Ralph. I'm going to work on it this weekend.
