J.D. 530 Heat exchanger?
D.B.T.
12-20-2006 17:06:27
I have a 530 with a cracked intake manifold. i have looked up new ones on line and most have heat exchangers advertised with them separately. I am not familliar with the heat exchanger nor its purpose. Do i need to get one of these when i replace the manifold?
Dan in Pa
12-21-2006 17:19:14
 Re: J.D. 530 Heat exchanger? in reply to D.B.T., 12-20-2006 17:06:27
You can get the old exchanger out by carefully cracking the casting around it with a hammer.I believe the exchanger is steel,not sure though,but the castiron breaks away from it real well. I have changed a few this way and never had a problem. The exchanger in the open setting allows hot exhaust gases to warm the manifold to help prevent the intake manifold from iceing up when operating in extremely cold tempratures. I always kept mine closed on my 520 here in Pa and never had any problems . Just giver some extra warmup time .
SM in Wi
12-20-2006 18:14:16
Sometimes you can use the old one, most time not. I say get a new one.
