Carb backfire B
peco9
12-20-2006 04:44:26
just rebuilt carb, adjusted to manual, under load at half throttle or more, backfires. starts and idles fine, magneto good, timed correctly. Just before backfire at throttle up, runs, then stumbles, and then catches up, the repeats. float setting off? Do I have a carb passage blocked? any suggestions to where to go from here? Thanks
George S. in the real NY
12-21-2006 05:04:35
 Re: Carb backfire B in reply to peco9, 12-20-2006 04:44:26
Also be sure there is not a hole in the manifold between the intake and exhaust. I got a '40 B with a brand new after market manifold and it had a hole. Very thin casting. Came from vendor in MI.
F-I-T
12-20-2006 10:01:44
Have you checked the compression? Since you said the timing was correct, you might have leaky intake valve. They will spit back under from that. Tappet clearance too tight?
P Browning
12-20-2006 05:47:06
peco9 -- There is a no-wrench test you can perform to ensure both IDLE and LOAD passage ways aren't blocked. Go to the JD-H Restoration Site (below) and over on the left, one-click on CARBURETORS. Allow the document to come up, then go to page 9 where you will find the testing procedure. Then post back as needed. (PatB)
