720D flywheel and fry oil
part-timer
12-19-2006 20:48:31
I posted a message a few days ago about getting a taperlock tight on my 720D. Lots of good advice from you guys and I got it good and tight. Unfortunately, it still does not go on far enough, so Allen Machine works says just machine off the excess on the collett. I guess it is coming back off.
Ran the tractor for about 2 hours today to get it up to temperature, and to burn the fry oil fuel out of it (Bought it that way). Runs good except that it wet stacks a little, but I never got it under load to really warm it up. Feels like a little less power than it should have, so I have a feeling that the fry oil does not detonate as well as diesel, particularly in the cold. Smells like french fries...
Hilltopper
12-20-2006 17:22:43
 Re: 720D flywheel and fry oil in reply to part-timer, 12-19-2006 20:48:31
I put one on my tractor a year ago. It lacked 1/4 inch going all the way. I glued a washer behind the cover at each bolt hole and it does not scrape. I have the fly wheel off now gettig a gear repaired.I plan to remove some of the excess on the taper lock before putting it back on.
mjbrown
12-20-2006 04:06:20
I had to do that with mine and took off a little too much and now have a spacer in there. When you machine it, keep the big square nut on it to help hold it together. I had to take off about 5/8" so I sawed off a 1/2' then used a mill to finish square and smooth.
