JD 3010 transmission
msgday
12-19-2006 20:29:23
My transmission makes a knocking noise in the mid dle forward gears.any help
Glen in TX
12-21-2006 07:39:25
 Re: JD 3010 transmission in reply to msgday, 12-19-2006 20:29:23
May need to look over some hydraulic components also? Knocking or grinding in the trans or see if the noise is being transmitted from something else? Clutch problems also. Does clutch seem to work okay or easy to shift gears? If the coupler on front hydraulic pump is worn or the plastic bushings shot you'll have a rattling noise coming from there. Maybe a noise from bad relief valve also. If you think it's the trans is it hard to shift or jump out of gear? Linkage parts worn not letting it go in gears right? Linkage has to be fixed first if worn and then go from there.
msgday in mississippi
12-21-2006 08:53:03
 Re: JD 3010 transmission in reply to Glen in TX, 12-21-2006 07:39:25
thanks Glen in The great state of Texas. I am thankful for your reply. when I bought the jd3010 the dash mounted shifter control was very loose and it wouldn't shift the gears right. I tighten it up and now it shifts in all (8) forwards and all reverses. The knocking only is noticeable in the middle gears.I have me a 3010 shop manual and I am reading to gain enough knowledge to inspect everything on the tracter.and thanks to good people like you . msgday
Glen in TX
12-23-2006 09:40:30
 Re: JD 3010 transmission in reply to msgday in mississippi, 12-21-2006 08:53:03
Sounds like you are on the right track especially with a manual in hand. All the worn linkage is easier and cheaper to fix first before tearing inside the trans. Also check the shift levers on outside RH side of trans and see if shafts are worn in trans case or splines worn on levers not being tight and causing some binding there too. The rails the detents fit into inside trans can get worn too and those that stuff not being maintained over the years is usually what causes more abuse to the rest of trans inside. If all that was kept up and proper oil changes most trans problems later wouldn't happen. But some parts inside do wear out also eventually on a 40 year old tractor.
