Duane Larson
Tom43
12-19-2006 19:47:50
Dear Duane,
I am intrigued by your answer to a lower post in which you state that a plugged bowl vent will cause a tractor to flood. You would expect the opposite in that there would be an air lock that would prevent incoming fuel from displacing air. A similar situation exists when a sediment bowl won't fill if the float bowl is already full of fuel. I know you know a lot about carburetors so please explain. Thanks, Tom
Duane Larson
12-20-2006 09:06:53
 Re: Duane Larson in reply to Tom43, 12-19-2006 19:47:50
Tom,
I've been tied up - I realized Christmas is approaching (duh) and it was about time to do some shopping.... so last night and this morning about got it.
Thanks to Glen and Glen for covering this - I agree with their comments. I assumed in the original post the tractor may be running when the problem was observed and I should have stated that along with my post. I believe your comment is related to a static situation when the engine is not running. I can try to expand on this a bit if you have further questions.
I hope the original poster lets us know what happens.
buickanddeere
12-19-2006 21:13:54
Duane, if I may. Too much pressure in the fuel bowl pushes extra fuel through the jets. Theefore a rich running engine. A JD fuel bowl is designed to be vented into the air/fuel path onto it's way to the engine. Instead of being vented to atmosphere. A rather clever design by Mother Deere to control air/fuel ratio under part and full load..
Glen in TX
12-20-2006 06:45:27
 Re: Duane Larson in reply to buickanddeere, 12-19-2006 21:13:54
Not trying to argue but wasn't the carb actually made by Marvel Schebler engineers and not JD ? Maybe not? Excellent explanation otherwise!
