329 engine
pjbrown
12-19-2006 18:18:20
I have a 2840 with a 329 in it. When I first start it up it acts like it skips.... it sounds like it runs on 5 cylinders. After 1 or 2 mins. of running it sounds and runs perfect. It doesn't use any oil. This March coming up I'm going to do a in frame rebuild on it. This coming weekend I'm go to do a compression test on it. Could any one tell me what it should have for compression. or any ideas what cause it to run that way when it's cold.
Turtle Gears
12-20-2006 20:35:36
 Re: 329 engine in reply to pjbrown, 12-19-2006 18:18:20
Frist thing I would do is put a gallon of type A tranny fluid in the fuel tank and go to work, this is a good conditioner,if this don't help then I would check my injecters. My 4400 JD combine has a 329 and it done the same thing it fixed it right up.Keith
Leon in Mn.
12-19-2006 19:58:27
Could be you have a bad or plugging injector. Those 329 engines use the "pencil" type injectors that need replacing after a period of time. They can be pulled out with a puller. An easy enough job for the do it yourselfer and a little patience. Just make sure that the injector lines are properly relieved of any pressure when disconnecting the lines from them. A rag around the lines helps keep the fuel from spraying under high pressure. It is also possible to have a pin hole in one cylinder sleeve due to cavitation. That makes it run rough for a while trying to burn out the coolant in the cylinder when cold. Check for coolant in the oil pan when cold and sitting for a day or so. Just slowly loosen the drain plug in the pan and watch for a small amount of coolant that would come out first. Hope this helps....
