1950 G Row crop Steering problem
W R Storm
12-19-2006 16:14:22
I bought a G that has a problem in the Steering. It will turn the wheels further to the left than to the right. Does that mean that the sector gear is out of time on the splined spindle? Thanks
Wes
Pappy
12-19-2006 22:36:48
 Re: 1950 G Row crop Steering problem in reply to W R Storm, 12-19-2006 16:14:22
P Browning is right. One more thing I do, I place a brass hammer on top of the shaft and then strike it with a 4 pound steel hammer. Drops out every time.
P Browning
12-19-2006 16:37:14
W R -- A really quick & revealing look can be had by removing the nose cone (medallion) and then the pedestal cover. Once open, you will see a pin either 5/8-inch or 3/4-inch diameter -- this is the stop the sector gear travels up to. As the tractor's wheels are at dead-ahead, there should be approximately equal distance to the stop pin for each end of the sector.
If it is off that mark by a bunch, you can unbolt the sector gear & reposition it so that (at dead-ahead) you do have approx. equal room for turns to the left or to the right. As I recall, the spline structure on your vertical spindle shaft is an eight-count pattern. Thus, each adjustment left or right amounts to 45� change in direction.
To get the gear loose, you usually have to (1) remove cotter & nut, (2) take the weight off the front wheels, and then (3) drive the shaft down. Step # 3 is most often very easy -- takes a small amount of shock -- block of wood on the shaft and a good rap with a hammer on the wood block.
This is also a great time to clean the cavity of old hardened grease, check to ensure the lock screw for the eccentric bushing is tight, and re-lube. Corn head grease is highly recommended for these gears. (PatB)
W R Storm
12-19-2006 17:53:05
 Re: 1950 G Row crop Steering problem in reply to P Browning, 12-19-2006 16:37:14
I have the I&T Manual. I have sprayed PB Blaster on the splines and gave it several hard blows, but it has not came loose yet. I cleaned all the grease out that I can get to . Should I heat the stereing sector?
You advice is greatly appreciated.
Thanks
Wes
P Browning
12-19-2006 18:38:44
 Re: 1950 G Row crop Steering problem in reply to W R Storm, 12-19-2006 17:53:05
Wes -- Sometimes those sector gears can be a struggle to break loose. Believe me, that is usually Good News. At least the spline relationship between gear & shaft is sound.
Now -- Heat can be a big, big help, but is not usually needed. Jack the front end of the tractor so that the wheels are high enough to be turned -- they should be clear of the floor by the slightest amount.
The nut holding the sector in place -- Take it all the way off, remove the flat washer that was beneath it, then put the nut back on the shaft -- turn it down to where you have a good amount (most all) of the threads engaged, but still have between 1/8 & 1/4 inches of space between nut & gear. The nut with full thread engagement provides the best protection to the shaft.
Place a really hard piece of wood, of even a piece of steel over the nut. It must be a nice tight, snug-up fit to the top of the nut; squarely placed. After all this preparation, one really good, square rap with a heavy hammer should drop that shaft. Soft wood will provide too much cushion. I emphasise that you strike squarely so as to avoid thread damage to the shaft. Striking off-center could conceiveably leave you with a bent end on your vertical spindle shaft! Be advised, that a replacement nut is readily available, but to bugger up the vertical spindle shaft makes you a sizeable headache! This should work -- oh, give it another shot of PB Blaster before you retire tonight!! (PatB)
W R Storm
12-26-2006 16:22:16
 Re: 1950 G Row crop Steering problem in reply to P Browning, 12-19-2006 18:38:44
Patrick,
Thanks for your help. A large piece of solid brass and a square hit and it dropped off.
Wes
