Ryan, You already did the correct n obvious things, whats left????? ? You say you checked the float so I reckon theres no feel or noise or sloshign of gas found inside it and if you immerse it in a cup of real hot water theres no tell tale air bubbles(a leak) rising?? Ive had them be a slow leaker but I didnt feel or hear nuttin inside the float but when immersed in real hot water there came them rising "tiny bubbles" and I heard Don Ho singing lol On that new needle n seat, I guees the lil orange o ring gasket at its bottom was in place when the seat was screwed down into the carb and it seemed to screw down tight?? Sometimes if its a straight steel n brass type (NOT the rubber/neoprene tipped) needle valve one can take a small hammer n lightly tap it down into the seat to help form a good seal. Ive heard tell where the bottom of that casting where needle seat is gets pourous n leaks When I have them reassembled I manually raise n lower the float to see if it feels nice n smooth with no binding and shuts off the flow but other then the above n assuming the float is NOT a leaker and the seat assembly is gasketed and screws down correct into the carb Im about left with a leaking porous carb??? Sorry no other help, let us all know what it turns out to be. John T
