70 diesel w/water in oil
Bobl1958
12-18-2006 11:26:29
Hey, guys. I have a 70 diesel that appears to be getting water in the oil. I know it could be a number of things, but is this problem common at all? Thanks-Bob
Blksmok
12-19-2006 08:29:08
 Re: 70 diesel w/water in oil in reply to Bobl1958, 12-18-2006 11:26:29
Bob...pull the cover off of the injector pump housing and look for cracks or welds under the pump on the pulley side of the engine. You should be able to see or feel any uneven sufaces on the floor of that housing. Also, if you don't have the new diesel head (3211 or 3511) your head will have injector tubes and seals that can leak. Third possibility is a cracked head. Usually if the head gasket is bad you will see water in the exhaust as well as water in the crankcase. Most common problem,though, is a cracked block based on my experience.
Bobl1958
12-18-2006 14:01:01
Thanks, guys. I was hoping for a couple of things to try first before I took the head off. I wanted to look into the simple things first. Thanks again-Bob
F-I-T
12-18-2006 14:19:47
 Re: 70 diesel w/water in oil in reply to Bobl1958, 12-18-2006 14:01:01
Bob,
A little air pressure, say 5-7 pounds, might speed up the diagnosis as well. Just don't over power the radiator, but the it might help expose the leak.
Mike M
12-18-2006 12:41:47
Those 2 cyl. diesels are masters at mixing their fluids where they don't belong ! So bad in fact I wonder if that's one of the reasons JD switched over to all one oil and reservior for the tranny and hyd. ?
Those early ones had injector well sleeves that can leak too. You may be able to pull off the valve cover and see if there's any evidence or a trail in there. Some people have been posting about cracks up in the injection pump area of the block may be worth a look ,not too hard to pull those covers off.
F-I-T
12-18-2006 11:40:54
I would not say it's common to the model, but it's not UN-common for them to contaminate the pony oil with coolant, due to faulty pony water pump seals and a pitted water pump shaft.
Now to get coolant from the diesel side into the diesel crankcase, that's a bigger issue and it would likely involve a crack in a casting or at minimum a leaking head gasket.
Places to look for cracks would be under the injector rack bracket (under the top cover), and then examine under the valve train (under the valve cover). At least that's where I would look first.
Frank
