Idle problems
Mingo
12-18-2006 07:33:35
48 B will not idle.It has a DLTX67 carb and Wico mag.Carb rebuilt, linkage adjusted to specs, timing checked ok. It starts and idles fine for about 30 seconds then with throttle still in idle position the RPM starts to increase with the throttle butterfly still in the idle position. I'm at a loss as to what to do next. Help please.
dan hill
12-28-2006 02:44:48
 Re: Idle problems in reply to Mingo, 12-18-2006 07:33:35
I found the idle passages had some fluffy material clogging them.This made the engine surge and the idle screw had no effect.
Mingo
12-19-2006 08:31:06
OK,sprayed starting fluid over the carb and the intake manifold and no change in the rpm. Now thinking about the govenor??? Thanks for your response
DickD
12-18-2006 19:14:55
Worst case scenario of what Duane said is--if the manifold gasket IS leaking and you have to remove it (God help ya!), be sure to run a straight edge on the head and manifold before reassembling it to make sure nothing is warped.
Duane Larson
12-18-2006 18:02:16
Mingo,
My guess would be an air leak in the vicinity of the manifold - either at the intake interface with the head, or where the carburetor bolts to the manifold. With the tractor running, feed some propane from a small propane cylinder around the manifold gaskets and see if the rpm increases. That should help pinpoint any air leak.
As extra unmetered air gets in the system it causes an rpm increase, like when the fuel is turned off and just before the tractor stops the rpm increases due to too much air for the amount of fuel.
P Browning
12-18-2006 11:58:25
Mingo -- yours is a classic case! Rather than render an opinion, I point you to an article in which you can diagnose this one for yourself. Go to the JD-H Restoration Site (below)and one-click on CARBURETORS. This is a nine-page piece, and on page 9 you will find a no-wrench test for both the IDLE and LOAD pathways of your carburetor. Me thinks you will be finding your problem as a result of doing those tests. (PatB)
Mike M
12-18-2006 08:04:42
Who rebuilt the carb ? and did they clean all the passages and reseal the little plugs ?
