Deere 4020 and 4000
Made in the USA
12-17-2006 23:26:14
I need some help from you guys who have had experience with the Deere 4000 (row crop not the compact utility) and 4020. I�m thinking of selling my older 65 4020 Diesel and going for a consol model but I�m having difficulty choosing between a 4000 or a newer 4020. Are the newer 404 engines better or worse? I do know late 72 models have a different block than early because they have a in-block heater but are there any problems out of them? As for the 4000 will it pull a 913 JD V-ripper or is the rear drive train not sufficient for this kind of work? Just a more general question will I be making a mistake moving into the newer years like maybe worn out tooling making sloppy parts for newer models or cheap outsourced parts from Mexico? And yeah I know all about the Manheim models they come as no shock to me nor the cheapo high priced India models but what about late 4020 and 4000, I know there was a 4025 for Mexico but where these parts also shipped to the US for the US versions?
buickanddeere
12-19-2006 14:51:33
 Re: Deere 4020 and 4000 in reply to Made in the USA., 12-17-2006 23:26:14
Intended to suggest a 4430, not a 4230.Either would work however.
Made in the USA
12-18-2006 16:59:57
Thanks guys your advice has been very helpful, thats why I always liked this site over asking someone at a dealership they just want to sell me something.
buickanddeere
12-18-2006 16:36:19
Can't hurt to look at some 4230's. The go for console 4020 prices or lower. 25+ more HP, a great cab, newer machine and heavier drive train.
Mike w J
12-18-2006 10:48:33
I have a 1969 4000 My dad has a 1971 4000 His was overhauled at 11300 hours Mine has 8000 on and has not been or need to be yet . His still did not use oil but it broke a wrist pin one cold morning . The tractors will pull anything a 4020 will pull . Mine has been a loader tractor for The last 15 years. His was his main farm tractor until 1978. He pulled 5/ 16 plow and 21ft. 230 JD disk on stalks in the fall 4th gear His had radial tires and duals. The 4000 has planataries That are 4000 only not like 3020 or 4020 inside axel size is I think like 4020 but outer end is the same size as 3020 . The 4000 has a 3pt hitch like a 3020 not cast iron like 4020 But it seems to be heavy enough .
sodly
12-18-2006 10:28:52
Were changes made to the late model 3020s also?
Gerald J.
12-18-2006 10:41:17
 Re: Deere 4020 and 4000 in reply to sodly, 12-18-2006 10:28:52
I think so, but I don't have manuals or parts books to compare.
Gerald J.
Gerald J.
12-18-2006 09:08:50
The 4000 and the 4020 side console are contemporaries. The 4000 was the lower priced model made to compete with other brands on price. It did have some smaller parts in the drive train, possibly mostly the axle parts. I don't have a parts book to compare them.
The 4000 and 4020 after SN 203,000 have a different block from the earlier tractors, with small differences in deck height to make pistons and sleeves not quite interchangeable but the major difference is that the later engines don't have the mechanical crankcase ventiation pump.
I don't think the production machinery was worn much by the 70s since it was new for the new generation. My history books point out that the reject rate on the two cylinder production machinery was high and that allowed more freedom in the new designs. I think that new 4 and 6 cylinder making machinery may still be in use because the same basic block sizes are still in use in many tractors. The gas 4020 engine I have is as long as the diesel, even though it doesn't have as many main bearings. That's from using the same machinery to bore both blocks.
The 4020 will have more sheetmetal than the 4000, like covers around the base of the seat. The 4000 is less common and so may get to be more collectible.
Either tractor may be more limited in traction than in power or power handling of the drive train when hitched to the ripper.
I think you will pay more to upgrade to a side console tractor than it would cost to put 404 sleeves and pistons in your engine. Just don't put the ones for a side console 4020, they will have a tad low compression and make it hard to start.
Gerald J.
Red_tiller
12-18-2006 08:52:58
I have a 1972 4020 turbo diesel. It has lots of power and seems to be able to do all the work I need it to. I don"t know about all of your other questions, but I love my 4020. No problems.
