Clutch Adjustment on 36 B
CalJim
12-17-2006 21:31:24
Hello,
I can't get clutch to adjust correctly. It will
engage and disengage fine but with very little
resistance. It is nowhere near the 80 lbs. force
the manual requires. 3 adjusting nuts are ran in
almost all the way, back them off and clutch will
not engage.
Crank splines are good, drive disk tightens up
good, 2 new facings, everything has been checked
for wear.
Tractor is being rebuilt so it is not running
yet but it should adjust closer than that.
What actually happens to create that "snap"
sound you can hear and feel when you engage a
properly adjusted clutch? CalJim
Glen in TX
12-18-2006 10:51:41
 Re: Clutch Adjustment on 36 B in reply to CalJim, 12-17-2006 21:31:24
Push crank over from clutch side and get proper flywheel clearance of .05 to .010" with no binding and then try some washers under adjusting nuts to see if you get closer. If not you are missing something that is worn or binding. Helps to have all the slack out of lever pivot bolt and bushings, pins, fork splines rebuilt or replaced with oversize ones getting all the slack you can out of linkage too. Was the fork worn any? Did you have belt pulley off cleaning and inspecting toggles and pins on back side for wear also? Grooves worn in clutch driver or crank splines worn with it loose? Are the springs old or were they replaced?
