4020 draft sensitivity problems
Dave Walsh
12-17-2006 18:57:57
I have a 1966 4020 diesel. The load sensitivity is not working right. Its always way too sensitive unless you put it in depth position. I need to use it with a 3 point scraper and a 3 point blade. I need it to sense light loads but it just wants to move way too much. Any ideas? Is there an adjustment to check?
Mike M
12-18-2006 08:08:13
 Re: 4020 draft sensitivity problems in reply to Dave Walsh, 12-17-2006 18:57:57
I can't remember for sure where ours is set. I need to check it out. One time it got moved and the blade would barely lift up very high. So these settings can make a big difference.
Gerald J.
12-17-2006 20:50:06
I checked my shop manual for pre side console 4020. The only adjustment is the speed of drop, that lock nut and screw on the back cover of the rock shaft cylinder, just above the anchor of the upper three point link. Turning the screw in slows the oil leaving the cylinder.
The shop manual suggests LD position is best for nearly all loads that need a little draft sensitive adjustment of position. It makes no comments about the L position.
I suppose the draft sensing bar could be broken making the sensitivity very high.
Gerald J.
low budget
12-17-2006 20:24:17
Someone jump in and correct me if I'm wrong, but I believe depth control SHOULD be used for back blade work. Load control gets "confused" on a back blade.
Tx Jim
12-18-2006 04:17:23
 Re: 4020 draft sensitivity problems in reply to low budget, 12-17-2006 20:24:17
low budget, I second your viewpoint on putting L/D in D for anything except pulling a plow. That is only place that any infinite operator control can be attained. Also there are several adjustment outlined in JD tech manual for setting L/D. Adusting for correct rockshaft valve clearance,adjusting control lever on dash,adjusting through bung hole in diff. housing(all set to specs. I don't remember) BUT I don't remember rate of drop screw being involved as that has to do with weight of implement. Tx Jim
