JD 530 overheating
D.B.T.
12-17-2006 16:38:47
My J.D. 530 has a problem overheating. The radiator, cap, thermostat, and waterpump are O.K. Any suggestions?
Tilar
12-17-2006 16:52:05
 Re: JD 530 overheating in reply to D.B.T., 12-17-2006 16:38:47
Have you considered that maybe the guage is wrong? I have an MT that shows constantly hot, but it never overheats. Shows running around 230 degrees after about 30 minutes.
buickanddeere
12-17-2006 16:41:11
Ambient air temp and type of load? Fuel type, mixture setting and spark timimg? Are you running this trator maxed out and lugging down?
D.B.T.
12-17-2006 17:20:31
 Re: JD 530 overheating in reply to buickanddeere, 12-17-2006 16:41:11
It overheats regardless of load. I am unsure about fuel mix. ect. Someone suggested that it could be a cracked intake manifold?
buickanddeere
12-18-2006 16:38:22
 Re: JD 530 overheating in reply to D.B.T., 12-17-2006 17:20:31
Tilar stated to obvious that I missed. Measure the water temp with a known good long stem thermometer.
