Coils on a pony motor
TOBY
12-16-2006 14:08:06
Opened up distributor on pony motor. First noticed wire to one set of points into. Second it smelled like the coils are burnt, Where can I get aftermarket coils and points or do I want John Deere. It looks easy to put back together or am I missing something. Thanks
DW
12-16-2006 15:54:50
 Re: Coils on a pony motor in reply to TOBY, 12-16-2006 14:08:06
The last ones I got from Deere, roughly six years ago were $176.00 each for the coils only. There are several places that advertise in Green Magazine with aftermarket coils for around $55 each. I believe in "genuine" parts, but only up to a point. My $.02 worth.
Glen in TX
12-17-2006 08:17:08
 Re: Coils on a pony motor in reply to DW, 12-16-2006 15:54:50
That's too much mark up on coils when you can buy the whole NEW B4027 Wico distributor for about $225 from any Wico jobber like me or others. The cheaper coil & tune up kits you find have import coils. You can't afford the new OEM Wico coils & tune up kit because for $20-$40 more you can go ahead and buy the whole new distributor now days especially compared to JD prices. JD didn't make the Wico B4027, Wico did so electric shops supply OEM parts for it actually and not JD.
Glen in TX
12-16-2006 14:34:06
The ones from JD dealer are same thing but just marked up more. There are the regular coils and import ones being sold and some dealers might even be selling the import ones if they dabble in aftermarket parts too. Either ones will work fine but make sure you only have 6V going into distributor and not leaving switch on when pony is not running. Do a search for FIT's oil pressure switch cutoff for your pony to help save coils next time.
rusty tractors
12-16-2006 14:30:06
I got mine from WTR parts. (605) 589 3128. I was very satisfied with the parts and service. They have the complete set of coils, points, condensor and spark plug wire set for 159.99
