84 JD 850 PTO problems
winter_rules
12-16-2006 08:28:59
The tractor has had a belly mower, which runs off the rear PTO, on it for 15 years. We tried to take the shaft out so we could run a bushhog on it. We talked to our local dealer who said it's common for the shaft to rust solid. Now we can't even get the PTO shaft back in. Is there any trick to doing this? We've monkeyed around with engaging and disengaging it but it just won't slip back in. It's about a centimeter too far out. Any help would be appreciated!!
Dan in Houston
12-17-2006 15:27:10
 Re: 84 JD 850 PTO problems in reply to winter_rules, 12-16-2006 08:28:59
Did you remove the four bolts and the rear seal housing, and then pull the PTO shaft out? My service manual shows the shaft with several retaining rings, spacers, etc. - don't think the shaft would come out the back without opening up the transmission and removing the PTO pinon shaft, shifter fork, etc. I would recommend you get the technical manual (TM1192 (Aug-86) is the one I have). You can find them reasonaly priced on ebay. The PTO shaft assembly takes several pages of detailed instructions.
