4430 hydraulic problem
Bill Hoff
12-15-2006 15:05:42
JD 4430. When pulling an implement such as a hay chopper, when I raise the implement, the PT stops while the implement is raising. When I lower the implement, the PT starts again. Why does the PT stop while I am raising an implement?? Thanks, Bill
Tx Jim
12-16-2006 03:11:31
 Re: 4430 hydraulic problem in reply to Bill Hoff, 12-15-2006 15:05:42
If PT means PTO it operates from trans pump pressure as does hi-lo and diff lock. Will tractor stop moving forward? Does having hi-lo in one or other make any change in PTO? Trans pump pressure regulating valve may be problem. Tx Jim
Bill74
12-16-2006 07:25:50
 Re: 4430 hydraulic problem in reply to Tx Jim, 12-16-2006 03:11:31
Thanks, Tx Jim. Yes, PT means PTO. This 4430 belongs to my brother-in-law who lives a couple miles down the road. He doesn't have a computer so I'm doing research for him, relaying messages back and forth. He did not mention that the tractor stops moving forward, just that the PTO stops. I'll relay your message, then get back here with more information if there is any. If the trans pump is faulty, would the tractor stop moving forward? Thanks, Bill
jddriver
12-15-2006 15:54:00
Sounds like the filter is plugged or the trans pump is bad or the valve on right side of tractor needs repair.Is this a power shift or quad range?
jddriver
12-17-2006 04:12:12
 Re: 4430 hydraulic problem in reply to jddriver, 12-15-2006 15:54:00
I meant left side
bill74
12-15-2006 16:08:38
Thanks for the reply jddriver. Its a quad. The front cartridge filter and the screen in the trans were recently changed and the oil has been replaced.
jddriver
12-15-2006 17:38:22
 Re: 4430 hydraulic problem in reply to bill74, 12-15-2006 16:08:38
check pressure at valve on left side of tractor
