Is this a 303 Gas Engine? Picture of it
Willy-N
12-15-2006 13:46:49
third party image
It is in a 95H John Deere Hillside Combine ser# 37788H Not sure if it is the 303 or not but here is a picture of it. Can you tell by the picture? Thanks, Mark H.
Turtle Gears
12-16-2006 14:56:21
 Re: Is this a 303 Gas Engine? Picture of it in reply to Willy-N, 12-15-2006 13:46:49
YES! THAT IS A 303 JD. T.G.
430LPG
12-16-2006 08:35:07
The 303 was used on serial #35001-up in gas, Lpgas, or diesel and says 90 hp
Mike M
12-16-2006 06:05:01
Well it seems like I misguessed. Been a long time since I saw a Chevy straight 6 .I knew Deere used them in some combines for sure. So what all was this JD 303 used in ? as I don't think I have ever seen one before.
95CS
12-16-2006 06:41:02
 Re: Is this a 303 Gas Engine? Picture of it in reply to Mike M, 12-16-2006 06:05:01
The 303 was furnished in either gasoline or diesel versions beginning with the 1967 model year for 55, 95, and 95-H Combines, and could be obtained in an LP-Gas version for the 55. It was also used in some early 6600 Combines with gasoline engines. The 303 was also used in a number of other Deere self-propelled machines, such as cotton pickers, and 4030 Tractors with gasoline engines. It was superceded by the 329 engine.
KIP in MX
12-16-2006 11:21:06
 Re: Is this a 303 Gas Engine? Picture of it in reply to 95CS, 12-16-2006 06:41:02
Yep, our JD 99 cotton picker had that engine on LP.
95CS
12-16-2006 12:00:02
 Re: Is this a 303 Gas Engine? Picture of it in reply to KIP in MX, 12-16-2006 11:21:06
A 99 Picker wouldn't have had a 303 on LP, would have been a 217 or a 248. The 303 engine wasn't used on JD cotton pickers until the 499 and 699.
MPK
12-15-2006 19:35:18
Yes, it looks exactly like the 303 on my 95 combine.
Willy-N
12-15-2006 20:20:48
 Re: Here is lots of pictures of the Combine in reply to MPK , 12-15-2006 19:35:18
Here are a bunch of pictures I took of it. It appears to be nice for a 40 year old Combine. It is still a working one with a few up/dates. Mark H.
Willy-N
12-15-2006 17:29:26
OK, I now got a answer that it is a HC-303-G 100HP Ebgine and a 1967 95H (Hillside) Combine. This will help me locate specs for it easier. Thanks, Mark H.
SM in Wi
12-15-2006 17:06:30
Yes that is a John Deere 303 power unit. I was 99% sure just by looking at your picture, but i looked at my SM-2054 service manual that has pictures of all of the power units use in 45, 55, 95 and 105 combines.
95CS
12-15-2006 17:02:59
No doubt about it, a 95H with that serial number would have had a 303 gas or diesel engine, and this one is obviously a gas. The only GM engine Deere ever used in a combine was a Chevy 292 six in the 4400 with a gasoline engine.
n
12-15-2006 21:26:49
 Re: Is this a 303 Gas Engine? Picture of it in reply to 95CS, 12-15-2006 17:02:59
I could have sworn my uncle's old 55 had a GM 292 in it.
Mike M
12-15-2006 16:48:38
Some of those combines used a GMC engine and I'd say that is one of them.
cannonball
12-16-2006 05:39:32
 Re: Is this a 303 Gas Engine? Picture of it in reply to Mike M, 12-15-2006 16:48:38
Chevy 292 fuel pump is in the middle of the block...
MAY GOD BLESS THE USA
Bob
12-15-2006 16:54:18
NO GM engine there!
Some 4400's, for sure, used the 292 Chevy truck engine, AFAIK, the 95 never did and the picture definitely shows a DEERE engine, certainly NOT a Chevy engine.
Bob
12-15-2006 16:54:21
NO GM engine there!
Bob
12-15-2006 14:05:28
Get the #s from the engine nameplate. It shows in the picture, just above the starter.
(I THINK it is the "303". There are also the 341 and 362 gassers, but they are a heavier-block design, looking like a 4020 gas engine. (Even quite similar to a 4020 diesel engine, and this one does NOT look like those.)
Willy-N
12-15-2006 14:25:38
 Re: Is this a 303 Gas Engine? Picture of it in reply to Bob, 12-15-2006 14:05:28
I will have to wait till the snow storm is over to see it. Tring to figure how to bring it home now and it is only 12 miles away. The roads are crap right now for driving on. Mark H.
