JD 530 bearing quill
James Porter
12-15-2006 08:07:01
I have read the previous post on this subject but haven't read anything concerning a 20 or 30 series tractor. I'm replacing a cracked (two of the ears) bearing quill B3585R on the right side of my JD530. I removed the right side tire, put the axle on a stand, pulled the belt pulley, clutch, brakes, first reduction cover, and got the bearing quill out. The bearing quill was tight and I managed to break off the remaining ear before it came out.
I'm now getting ready to put the replacement bearing quill back in. I read in my manual that shims on the left side bearing quill determine the correct end play which is measured with a dial indicator at the ring gear.
1. I have not separated the rear axle housing from the main case and wanted to know if there is a way to obtain proper endplay without doing so?
2. I will need to pull my race from the bearing quill. I read in one of the posts that it is prone to crack so it should be welded. How is this supposed to be done?
3. The bearing quills have a groove on the circumference which holds a packing o-ring, so no gasket is required. Do I still need to use a sealant under outer edge of the bearing quill, between the shims, and on the bolts?
Thanks, James
machinery-man
12-15-2006 11:26:09
 Re: JD 530 bearing quill in reply to James Porter, 12-15-2006 08:07:01
This is a slow moving and large bearing. End play is not exactly critical as all the years of use I'm sure it has wear but if concerning before you put the O ring on quill 0 it up and then feeler gauge the quill to case to see what clearance is needed. Also a lot of reason they are broke is folks pulled the quill in place by the bolts. Take a rubber hammer and tap it in place. The differential will stay close in place as it is sitting on the bull gear. Tap it in place then snug up the bolts.
machinery-man
12-15-2006 11:25:47
Kurt_JDB
12-15-2006 09:24:49
James,
I think you are going to have to split the tractor to set up differential side to side play properly. It should not be that big a deal if you put the right side wheel back on. Block up under the front half of the tractor, ease out the bolts and roll the back half away. I bolted a 12 foot 2x8 to the drawbar of my tractor so it extended straight back and used that to "steer" it back and then let the end of the 2x8 rest on a block to keep it all stable.
My tractor is a '51 B, but I belive it is essentially the same. I was able to rebuild the transmission and do the whole job, including replacing the differential bearings without pulling the wheel off at all. It was set out as wide as it would go.
I suggest replacing the entire bearing assembly on both side of the differential, if your going to split the tractor.
Kurt
machinery-man
12-15-2006 08:23:37
Looks like you have made a major job out of it. The last one I replaced, I took the brake off. Nickle welded a bolt to the center so I could pry it out. Reinstalled the race in the replacement quill installed the shims and a new rubber o ring, greased with never seize, worked the quill in 3 bolts in place, brake back on and job finished.....
Mike M
12-15-2006 08:19:03
For some (unknown to me)reason those 2 models seem to have a problem with those quills. I had to replace a few and was hard to find good ones and even harder to keep from breaking them when I removed them. I usually add some silicone sealer around that seal and flange to help it seal.Welding to remove a bearing race is only for bearings you don't want to save as you have to weld right on the bearing surface then when it cools it falls right out. You should be able to get a puller inside on that bearing and pull it and save it. If you trial assy. it with no shims then you can measure the gap and add shims plus enough for clearance and then final assemble.
