Bad starting 4230
C Clark
12-15-2006 02:24:21
Am having trouble starting my JD 4230; especially during the colder months. It has a rossa master fuel pump which I understand lacks excess fuel during start up. I would like to fit a bosch pump to it. But don"t know how easy this would be.
Any thoughts?
mlauk
12-17-2006 11:12:50
 Re: Bad starting 4230 in reply to C Clark, 12-15-2006 02:24:21
Best thing I did for starting my 4230 was add a manual destroker on the hydraulic pump. It costs around $15. There are 2 available, so make sure you get the right one.
adsma
12-15-2006 14:12:20
You may also want to consider installing 2 12 volts batteries in place of the 2 six volt batteries. The later 50 and 55 series tractors went to this setup in order to allow them to spin the engines faster for start up. Depending on what your battery cables are like you might want to consider installing the newer style battery/cable setup. Depending on the condition of the engine,as a last resort you may need to do a valve job,replace the injectors, and/or install a different rebuilt injection pump. Or like the other responder said try and advance the timing and see what happens. It seems like once the nonturbo tractors start getting the hours on them they become hard to start and i know of a lot of people that woundup doing a valve job, replaced, the injectors and pump and adjusted the timing, they became good starting tractors once again.
Leon in Mn.
12-15-2006 09:58:40
Try this. It works for my 4030. Heard this from a JD man. When you shut it off when warm, push the stop knob back in again and advance your throttle lever all the way forward and then back, then about half way again, and leave it that way till the next start. I have started my tractor this way when it was already 18 degrees without even plugging it in! Although it also helped alot since replacing the Delco starter with a Nippondenso, and you need to have good batteries, and clean connections. Try it.
jdemaris
12-15-2006 06:07:15
Most of the Bosch-pump tractors we sold started worse, not better - in cold weather. Spend $10 and install a manual pump destroker and it will be much better. The Roosamaster/Stanadyne DB pump can provide all the fuel that things needs to cold-start. You might gain a little by turning it up an 1/8 turn and also bump up your initial timing a few degrees. The pumps sometime get low in fuel delivery over time and high engine-hours. We had our share of cold-starting problems with the 4230s when new - most did not start anywhere near as well as the 4020s. There were many issues besides the fuel system. Starting even got worse with the 40 series, and finally most got fixed when the 50s came out.
J Schwiebert
12-15-2006 04:02:13
When it starts or even when cranking over do you see a lot of smoke and if so what color is the smoke?
Tx Jim
12-15-2006 03:55:18
A Bosch pump similiar to a 4430 in my opinion would not help starting because of the aneroid. I think I would install an elecric hyd. pump destroker and a block heater if not already equipped if it were mine. Tx Jim
