4020 Synchro Troubles
huffjdeere
12-14-2006 11:23:15
My father has a 4020 with the synchro shift tran that doesnt seem to mesh up in the gears correctly. The only gears that will engage correctly are the "up" gears i call them on the shift pattern (1,2,4,and 6th). These gears are even a little tricky to find the correct engagement(grinding and popping out etc). All three reverses also work correctly. Now the other gears (down gears 3,5,7,and 8) will not mesh up at all. The just pop out or grind as soon as you release the clutch. My question is basically where to start the diagnosis? Is it in the linkage somewhere, synchronizer, etc. Any help on where to start would be greatly appreciated. We split the tractor last fall rebuilt clutch and adjust the pressure plate. If i remember correctly it started acted up shortly after. I dont think we could have done anything wrong there?. The clutch is not the issue becuase it works fine when using certain gears. Thanks for the time and any help will be greatly appreciated.
Gerald J.
12-14-2006 20:18:41
 Re: 4020 Synchro Troubles in reply to huffjdeere, 12-14-2006 11:23:15
1,2,4,and 6 all use the same gears and the same point on that shifting cam. 3, 5, 7, and 8 use the same cam further on. All reverses use that same cam and the same gears, but the drums on the cowl are supposed to prevent getting to the third range reverse. Some fileing can enable that fast reverse. It was locked out in the 4020 because the torques were more than the gears could take.
You shift ranges on the left side, and shift the efeective second transmission on the right side.
Unless the shift drums have been modified up at the cowl, getting to third reverse hints at maladjustment of the linkage. Its always nicer to fix linkage than transmission, but it is possible for there to be problems inside and outside the transmission.
Gerald J.
huffjdeere
12-14-2006 19:28:17
Thank you all for the inputs. I will be sure and perform the linkage adjustment in the manual first as Jason and Bob say.
However if I need to dig deeper, I thank you Kent for the detailed explanation of what to look for/replace. I will post back and keep you all updated.
Kent Petersen
12-14-2006 18:21:17
if you are going to pull the cover off get the tractor in the shop so you can just go ahead and split you need to split beteen trans case and clutch housing remove 3pt housing and seat as a unit. you can now remove top shaft and rebuid synchros new shift fork uses a long bolt and spacer to hold fork strait in line with shaft keeps it from rocking up and down on syrco drums i would replace bushings, spacer washers and pivet pin in shifter also pins in top of shift rods also check pin fit in clevis on top of rods i am 99% sure the scyros are ware out 40 years working on 30 and40s lol Kent ps let us know what you find
KIP in MX
12-14-2006 16:09:52
You can get it into 3rd reverse? I thought that 4020s only had two reverse shifter slots, even thought I understand that the 3rd rev. gearing is still there.
Jason Z in MO
12-14-2006 13:29:08
Did you follow the linkage adjustment procedures in the service manual after splitting the tractor?
I worked on a 4020 which was really tricky to shift until I followed these steps. Since you had it split you had to remove these linkages.
Just a thought,
Jason
Bob
12-14-2006 11:47:14
If the quadrant and linkages are reasonably tight (free of excess play), and adjusted correctly, you have shift fork or synchro/shift collar problems.
Do you know if it has had the shift fork and synchro updates?
Remove the deck, then the tranny cover. You can then check for a broken fork, or see if the syncros are worn and out of place.
huffjdeere
12-14-2006 13:22:55
 Re: 4020 Synchro Troubles in reply to Bob, 12-14-2006 11:47:14
Bob i know we havent had the updates, the tractor has been in the family since new. So you can remove the tranny cover under the footrest to look into the shift forks?
msb
12-14-2006 19:03:44
 Re: 4020 Synchro Troubles in reply to huffjdeere, 12-14-2006 13:22:55
Bob is right on as usual.If the tractor hasn't be severely abused or have a ton of hours on it, chance are a little adjustment of the shift linkage is all that is needed.Jiggle the shift lever to be sure the detents are seated and then adjust the linkage to where the shift lever is squarely in the slot when you move it to the right into each range.
