2640 hyd.
davids
12-13-2006 16:32:56
3 pt. works but the loader wont. The remote levers wont return to center and the valves have a noise like oil is by-passing all the time unless you hold the lever in the center poisition. Do the remote valve bank have a relief valve in it or do I have bigger problems? Any help is appreicated. Thanks, davids
jdemaris
12-13-2006 17:49:46
 Re: 2640 hyd. in reply to davids, 12-13-2006 16:32:56
If you're talking about the Deere selective-control type of remotes - there is no relief valve. There are four spool valves inside if it's a dual model - two inlet valves and two outlet valves with adjustable linkage that operates them. Probably also has a rate-of-flow adjuster? Best just pull the cap off the back and look inside. Doesn't the valve-lever usually stay in neutral position by itself?
