4440 load shaft bushings
new 4440 owner
12-13-2006 16:12:29
I can't drive the load shaft bushings out of the trans case. I've done this job on a few 20 series tractors and have always been able to pop them right out using an old load shaft. These ones fit tight. Any tricks?
Glen in TX
12-14-2006 08:38:58
 Re: 4440 load shaft bushings in reply to new 4440 owner, 12-13-2006 16:12:29
Check at JD dealer with shop manager for specs on the bushings and shaft as most all SM**** service or TM**** technical manuals gave bushing and shaft specs giving you idea if they need replaced. If egg shaped any or a line you can see and feel with fingernail or you done burred it up trying to drive on it it will need changed. Like Jim said it does wear the holes out in case changing them too much. Not sure on the 4440 but I know they made bushings that were oversized some on O.D. for 4010/4020 so if you pull out the old bushings measure the O.D. before ordering some new ones. I've pulled many bushings with a slide hammer puller also but you won't always have room to get one in there if wheels are set in too far.
Tx Jim
12-14-2006 03:53:51
Are you sure load control bushings need changing? JD stated when I worked for a JD dealer to only change bushing as needed because changing frequently bushings can get loose in case. Normally a new shaft and seals stops leaks. I have a JD 4255 that has 9200 hrs with original bushings. Tx Jim
