1010 special RUS distributor
fixitman
12-13-2006 15:54:03
I have a 1010 special that I want to buy an electronic ignition conversion kit for and I need to identify the distributor to get the proper kit. My manual shows 3 different distributors for the tractor. Wico, Prestolite and Delco. Mine has the clip on cap. Tractor is one of the last 1010's made, high serial number.
I can't find any identifiers on this dist. JD dealer was no help?
Can anyone tell me how to id this thing.
jdemaris
12-13-2006 17:42:49
 Re: 1010 special RUS distributor in reply to fixitman, 12-13-2006 15:54:03
Delco can use a screw-on cap or a clip on, and the Wico and Prestolite are also clip-on. Delco clip-on type distributor 1112577 has the clips held to the distributor body with screws. Wico clip-on type X30091 has clips held on with hooks on the clip-ends - i.e. no screws. Prestoline clip-on type IBT-4101 also has its clips fastened to the distributor body with screws (like the Delco)- but if you look inside the Wico only has two advance weights - whereas the Delco has two PAIR of advance weights - i.e. four of them.
